Viewing 4 posts - 1 through 4 (of 4 total)
  • Rock shox/SRAM MMX mounts?
  • thisisnotaspoon
    So…….
    CRC have a stock of Reverb posts at £200 with the MMX mount, which shifters and brakes does this work with, I heard it was just XX kit, is that true, or wil my lowly Elixirs work with it?
    enmac
    It works with any brakes or shifters as you can remove the mount and just attach the clamp. I don’t know whether you can do away with your Elixir clamps though as I have Hopes.
    thisisnotaspoon
    So the MMX clamp is a seperate bit bolted onto the standard clamp and easily removed?
    Just wondering why they’re £50 cheeper if they’re universaly compatible.
    dhrider
    It doesn’t come with a bleed kit….
The topic ‘Rock shox/SRAM MMX mounts?’ is closed to new replies.
