Great forks… My 2-step exploded in the post before I ever got to fit it 😆 Quality. Converted to U-turn, never looked back. And you don’t want the R version without compression damping adjustment, it’s a much worse fork and you can get full mission control for not much more.
The solo air spring is actually good, think it’s bigger than most. But I reckon these days if you want light you should probably get a Pike, since even with an air spring the Lyrik’s a big slab of metal. I prefer the performance of the Lyrik but it’ll never be light. Height adjustment, I don’t know about, I’d think it’s alltravel spacers for the air.
The damping in the Mission Control versions is actually all pretty similiar, and all good. The Lyrik DH has no propedal/lockout setting which is no loss, and does perform better as a result but you can easily remove that from older forks to get pretty equivalent performance. I can’t remember when the dual flow rebound adjuster came in, quite late on, it’s worth having but not gamechanging.
There’s no terrible Lyriks, they use the Domain as the budget version mostly. Mine are fantastic, I’m a weight weenie but they’re so damn good I don’t mind.
