I have a Genesis Equilibrium road bike with Tiagra compact cranks. I replaced the factory fitted Shimano HTII BB with a Hope BB. The BB shell is 68mm wide according to the Genesis website.
I’m really confused as there appears to be 1-2mm lateral play. I.e. the crank is a tad too wide to nip both arms up flush to the bearings. There is space between the cranks and the bearing face which results in the crank moving left / right if I give it a knock. According to the Hope BB selection table fitting the 1mm spacers either side is enough.
I’ve tried tightening the preload tensioner on the crank to try and bring the crank in but it just won’t go any further.
Any ideas?
