Well I finally bought one. After reading glowing reviews I went for the Cateye Volt 1200, and so far I’m impressed.
In comparison to my XML-L2 Cree torch, it is considerably brighter, the light is much whiter, and the beam has a much better spread. Even if you ignore the unit itself, the actually quality of the light just looks way better. I tested them side by side, and it made the Cree look cheap with a poor beam and hollow blue light.
One of my big concerns was that a few reviews had brought up having to scroll through the flashing mode when changing settings, but it’s actually not the case. The flash only mode only activates via a double click, so you just need to make sure you scroll through the modes slowly to avoid it. Would be nice to be able to scroll up or down modes, so you could go from high to low and back again, but it seems to be decent value in comparison to some of the competitors, so I can live with it.
Will see how the mount holds up, but I’m sure I can get a new one if it fails.
The 700 may well have been powerful enough for the road, but one of the deciding factors was the battery life on the 1200.
