I’ve been using 28s on Stans Podium MMX rims on a recumbent bike. They’re sublimely comfortable, but I’ve had a couple of scary moments, due, I believe, to the low pressures – Stans recommended a maximum pressure of 40psi and an absolute maximum of 50psi. There’s a bit of uncontrolled ‘bounce’, most noticeable when trying to keep a straight line up steep hills (not easy on a recumbent). The scary moments came when cornering, and probably when the tyre pressures had dropped – presumably the tyre rolled slightly or the sidewall deformed, but I seemed to be drifting and about to high-side. The feeling made me sit up in my seat to try and regain control, whilst quickly offering up a silent prayer! I’ve recently stopped using the wheels – I was out on a ride and the rear tyre started to leak, and I couldn’t get it fully sealed at the roadside. When I got home I replaced them with the original wheels, and although they’re not as comfy or fast, I feel a bit happier with them.
