neilsonwheels – Member
Depends on how fit you are. Personally a compact is only really needed if you live in the mountains, Britain doesn’t have proper mountains. A 53/39 with a 28 out back will cope with pretty much anything.
Really?
Galibier is an average of about 8% with a peak gradient of about 12%. I live in Kent and on my ride to work I have a hill which is 14% and any number around here which are over 20%.
I ride in the Lakes on holiday where Hardknott Pass is over 30%
It’s the gradient not the length of the climb that affects the gearing needed. OP, forget the willy wavers – you will probably be faster up any climb longer than about 1km by sitting and spinning rather than grinding your way up.
Look at what happened on the key climb of the Vuelta in 2011. The Angliru is 23%, Cobo won it with a bottom gear of 34f 32 rear. He destroyed Wiggins who was running 38f 32 rear and ultimately won the race. Now I have nowhere near the power of these guys but when climbing anything steeper than about 15% then I like my 30f 28r bottom gear.
Gearing is a personal thing and ultimately only you can decide what is right for you, but don’t be swayed by others telling you that your gearing is too easy or to just MTFU.
