Viewing 12 posts - 1 through 12 (of 12 total)
  • Road Bike- bars keep slipping.
  • codybrennan
    Whenever I hit a biggish bump on my road bike, the bars will rotate a wee bit downwards with my weight. Its a Ritchey stem, Cube Aero bars.
    Tightened the **** out of the stem bolts already.
    Any tips for keeping them locked?
    RealMan
    Less weight on the bars?
    If you’ve already tightened up the stem bolts massively, I’d take it apart and check everything out. Is it new stuff? Maybe the bars are a bit thin, or the stem is a bit big?
    gee
    Sounds like you haven’t done the bolts up evenly. Make sure the bars are centred in the clamp and that you have the same amount of thread visible on each bolt. Tighten them alternately.
    codybrennan
    Could be RM. I’d swapped the stem from my Cube to the Boardman, and its the Boardman thats demonstrating the issue. Might be one is 25.4, one is 26. Will check.
    orangeboy
    Carbon assembly paste
    It’s like grease but with bits in it sort of like swarfega orange
    Stops seat posts bars and the like moving with out crushing the hell of of them
    If bars are alloy then I’d not recommend this fix as you prob have other issues
    codybrennan
    Gee- will check that out too.
    fasthaggis
    Check that there is not a high spot inside the stem. I once put a wee bit of wet n dry round the bars. It worked and I didn’t die 🙂
    roadie_in_denial
    A bit of olde-worlde Roadie wisdom, although with the advent of modern technology and manufacturing processes this is, perhaps, a mite olde hatte by now:
    Fit handlebars and stem made by the same manufacturer as small differences in tolerance and manufacturing techniques may present themselves in the form of creaks, or in extreme cases, movement.
    But as has already been said…I would reckon bolts aren’t evenly tensioned.
    Don’t over-tighten tho. Tight’s tight, stripped’s knackered.
    codybrennan
    All good advice- cheers.
    Vinnyc
    Try some fiber grip
    oldgit
    Take off, clean off any white residue with soapy water and dry. Tighten up evenly and slowly.
    Make sure the bolts have their washers so they don’t run out of thread.
    Of course the ‘old roadie in me’ see’s the word Cube and instantly blames that POS brand.
    (POS IMO all rights reserved)
    Edit. Ask for a mini torque wrench this Christmas.
    epo-aholic
    what Vinnyc said, fiber grip will sort it, tried everything with a post and the=is stuff worked first time 😀
The topic ‘Road Bike- bars keep slipping.’ is closed to new replies.
