Just tried fitting a Maxxis Holy Roller to a new Stans Crest rim. Probably the hardest tyre I ever fitted! I had to resort to a tyre lever in the end.
The problem is that the tyre bead is sitting on the rim tape and because it’s so tight on the rim I simply can’t move it off and it looks like it’ll cause me problems if I pump it up – i.e. big bada boom.
I’m not expert in wheels and I bought the new rims as a wheelset from Superstar. Should the rim tape be so loose fitting that it moves around when fitting the tyres? Or even with a very light prod? The tape on my old wheels is very solid and doesn’t want to be moving anywhere, or does that come with age and use?
