No, it’s 8′ deep, 4′ wide and 4′ high with a full 4’x4′ door on the end. The panels are made from 3mm galvanised steel plate welded onto a 50mm angle iron frame. The side against the wall is done in 50mm weldmesh for ventilation, cost and to give me a fighting chance of picking anything up that falls down the back.
Gate hinges welded onto the door and getting on half inch thick slide bolts to lock it. Door has an internal angle iron frame to make sure it can’t be lifted.
Plates are welded to the base and expanding bolts into the concrete garage base to fix it down with a resin in there just to be sure.
I’ll try and get some photos on somewhere to load them on here later. Jeeze I wish you could just do direct uploads or it’d recognise ampersands.
