Home Forums Chat Forum Ride this morning so fancied a sit down…
Viewing 20 posts - 1 through 20 (of 20 total)
  • Ride this morning so fancied a sit down…
  • WorldClassAccident
    but all i could find was this
    so I thought this
    found this and something to cut it with
    Unfortunately the drill bit broke so I couldn’t finish the base mounts for the uprights
    so I cleaned up the old shocks and sprayed them with undercoat ready for a top coat tomorrow
    Hopefully an update tomorrow when I get a drill bit, some top coat for the shocks and a scaffold plank or similar for the seat.
    teasel
    Dude…fuxupwitchoo…?
    jambourgie
    Brilliant!
    You should probably install the seat in your car 😉
    bedmaker
    Reminds me of a silly project years ago where I used a few turns of a car coil spring to build an adult size baby bouncer type chair for a mate.
    I upholstered it in red fabric, it looked dead cool but was horribly uncomfy!
    A big one of these
    WorldClassAccident
    Last chair I did was a single seater – remarkably comfortable and less deadly that it looks.
    Thought I would do a two seater this time
    Freester
    Sorted
    Sandwich
    I wonder what A&E will be dealing with later today? Looking forward to pics of the finished item, or the inevitable gore fest prior to a ride in the ambulance.
    donald
    Brilliant!
    WorldClassAccident
    A bit of progress but spotted a design flaw in the last shot
    Compressing the springs to refit after painting the shocks and floor rests
    One half assembled and mounted to the bench top / scaffold plank
    Other side on and notice there is an issue with the suspension camber
    Concrete blocks solve that but then MrsWCA points out the obvious…
    …swap the legs around and use the wheel mounting bracket, currently on the outer edge of the shocks, to hold a support bar between the legs so they are vertical.
    Sitting on it is comfortable enough but not much in the way of bouce. I guess I weigh less than the front of a BMW. Maybe a couple of people would make a difference.
    We will see what it is like with the legs swapped and an anti sway bar across the middle
    scaredypants
    or, maybe you could launch yourself off – ooh, I dunno, maybe a ladder – and see if that improves the compression
    molgrips
    Hi, Molgrips! Come in, have a seat!
    Er no thanks, I’ll stand. Hope you don’t mind.
    thegreatape
    Do you live in a windmill, own a flying car, and have a bird called Truly Scrumptious?
    Looks, er.. heavy.
    WorldClassAccident
    DezB – I will use alloy for the cross strut and remove the four concrete blocks to lighten it.
    Chitty Chitty bang bang? No, not yet but there are plans…
    See the front of the pick up? With a bit of angle grinder and vision, perhaps, just perhaps…
    thegreatape
    I have faith in you
    timba
    Anti-sway bar needs to go diagonally from each side and attach to the seat centre, rather than side to side
    dudeofdoom
    Balance a spare engine on your lap and it’ll be just fine..
    WorldClassAccident
    Exactly the same conclusion I came to on the drive up to work this morning – you are a genius
    lerk
    Assuming the shocks are not completely goosed, the nitrogen charge should be enough to hold most non-clydesdale types – take the springs back off and have a try!
    WorldClassAccident
    All completed and painted now
    Now on ebay with a cheeky buy it now price. If anyone on here wants either just email me an offer
    http://www.ebay.co.uk/itm/111702896106?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
    http://www.ebay.co.uk/itm/111702900303?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
The topic ‘Ride this morning so fancied a sit down…’ is closed to new replies.
