Viewing 6 posts - 1 through 6 (of 6 total)
  • Revit – learning from scratch
  • scruff
    I’m good with autocad but need to teach myself Revit 2018 architecture from scratch. Any recommendations for on line free guides? The Autodesk community has loads but too many if anything.
    scruff
    Oh yes, the tutorial videos link from Revit goes to a bad link, and can’t access YouTube.
    mikey74
    The Autodesk wiki has quite a lot of info. I would suggest measuring your house and building it in Revit. That will give you something to focus your efforts on.
    scruff
    I’ve got 3 hospitals to practice on 😯
    mikey74
    Oooo nice. I would suggest jumping in with both feet: I found that it was easier to do the easy stuff in Revit than in Autocad, but it is harder to move on to the advanced stuff.
    Try just going in and drawing walls, inserting doors and windows,adding dims etc and then when you come up against something that is not obvious, then google it.
    These are a few links that may prove useful:
    http://www.dscohn.com/AU/handouts/AB322-1%20-%20Raising%20the%20Roof-Creating%20Roofs%20in%20Revit.pdf
    http://revit-detail.blogspot.co.uk/2011/01/0900-house-extension-project.html
    https://www.nationalbimlibrary.com/Object-Types
    scruff
The topic ‘Revit – learning from scratch’ is closed to new replies.
