Reverb woe...
[Closed] Reverb woe...
[#3743743]
Thought my Reverb needed a bleed. Pumped it up to 250psi. Cycled it down and up once and 130psi leaked out.
So I guess it's dead. Back to the shop it goes...
Question is do I get a replacement or do I get my money back?
Posted : 05/03/2012 9:17 pm
Deja vu anyone?
Posted : 05/03/2012 9:21 pm
 Del.
Same happened to mine..sent it back & RS apparently fit the newer 2012 internals in to fix. ( unless you already have one of the later models,which would be worrying )
Posted : 05/03/2012 10:04 pm
Sent mine back in early January and they sent me a new 2012 model
sorted!
Posted : 05/03/2012 10:11 pm
 v10
Not saying it isnt broken but you do realise that you get a BIG apparent pressure drop when reattaching a pump to the post?
Its a pretty small air chamber so a decent percentage of the air in it is used to fill the hose/gauge on the pump when you connect it..
Posted : 05/03/2012 10:22 pm
Same happend to mine today, I was told that it is an O ring that fails inside and they get repaired as above so it doesn't happen again.
Posted : 05/03/2012 11:32 pm
