Why would the reverb suck it up?
I’m as surprised as you.
Full story. Shitty wet day in the alps, took to the hose-down area at the bottom of the lift which involved hanging the bike from the front wheel.
My bike has a sort of ‘semi stealth’ set-up, the hose comes out of a hole at the bottom of the seat tube – this hole is much bigger than the hose (there’s meant to be a bung, but it’s long gone) and let in a lot of water.
Without thinking too much about it I raised the seat to hose down the underside of the saddle, thought no more of it, took it back ‘home’ and it spent the night in the garage.
Next morning the seat wouldn’t go down, wtf? I argued with it for a bit before finally it went down, and a load of dirty water came spraying out of the hole in the seat tube. I sounded a bit shitty for a bit, but for the most part is good as it’s ever been since, but I’m wondering if I should strip, clean and oil it.
I assumed it was a sealed unit like a fork, but the above makes me think it’s takes and returns air to the seat tube when it works.
