1. Unscrew remote from hose (hold the hose and twist the remote)
2. Screw one side of red barbed connector into hose (should have come with reverb)
3. Get a length of brake hose/gear housing and screw onto other end of red barbed connector (ensure hose/housing is long enough to go from bars to top of seat tube.
4. Undo seat clamp and remove post – gently! The reverb hose will pull the housing/hose through your frame.
5. When the barbed connector appears at the top of the seat tube, unscrew from your reverb hose, leaving the housing/hose in situ.
6. Reinstall reverb remote and send off for service/warranty etc.
7. To re-install, reverse the steps!
