I’ve fitted my Reverb stealth to my bike, bit of a pain as I needed to use a new hose. I’ve tried to bleed it and I’m having no joy at all.
I get to a point where using both syringes I can push one in and the other rises, so assume no air in the system, button it all back up at the post, bleed the lever, refit the bleed screw, press lever and nothing, it goes straight to the bar. Bleed the lever again and get the same result.
I’m assuming that there is air trapped somewhere in the hose, possibly where the hose twists and turns through the frame.
My next thought is to remove the system from the frame, bleed it until, it’s working, then, remove the lever, block off the hose, refit to the frame, then refit and bleed the button.
Anyone got any other ideas…
ta.
