I have a 2011 Rockshox Reverb. I have had it from new and it’s just over 6 months old. It’s always been clean after every ride etc.
From new it always had play, I took it back a couple of times to the supplying LBS to always be told ‘a bit of play’ is normal.
Then this weekend on a long ride I heard it scrape / crunch quite loudly when trying to drop it down. So I stopped to check it out and below is what had occured…
During the ride its developed a very faint rub in the coating from the bottom to the top of the stanchion… but more specifically there is now a 1mm deep, 2″ long scrape in the stanchion coating.
It still functions as it should, except now it crunches and grinds when going up and down. I’ve obviously stopped using it sstraight away and have since dropped it into the supplying LBS.
Any guesses at what sort of response I can expect from Fisher Outdoor / SRAM.
Out of interest is there any kind of service required with the Reverb, mine’s been fine, but people keep talking about how their Gravity Dropper is like new after a new bushing/key/seal service, or their KS post only costs £10 to get serviced, or whatever post they use is fine as logn as they strip and clean it every few rides. Never seen or heard anything similar for a reverb?
Never seen a recommended service interval but this video show’s it’s not rocket science. You could easily do a quick strip, clean and re-lube (based on this) without actually replacing every seal too…
You kept using it after it started making awful noises?? Were you hoping four a total failure?
I reckon one of the brass keys has slipped. If you watch the deconstruction videos on youtube (EDIT: that one above) you’ll see what I mean. Hopefully that’s a warranty thing.
TINAS – Apparently you can send it back to Fishers for a service (inc seals) for £30 ish. That’s what my mate reckoned anyway. That’s probably worthwhile.
I know I shouldn’t feed a troll. but please read what you quoted…
I obviously stopped using it straight away
After identifying that it was crunching when going up and down, I immediately stopped using it.
Unfortunately I forgot to take my spare seat post with me though on this particular ride 🙄 so I had to continue sitting on the extended seatpost until I got back to the car.
My old man wrecked his in a crash, still got it fixed under warranty FOC. Jedi sent his back recently and had a positive outcome too. I’d hope your experience would be similar.
I’ve heard that about 3-4 days from bike shop back to bike shop is fairly typical. I guess you’d need to speak to them and see if they’ve got a lot on, though.
We plan on doing quite a bit of XC on top of the gravity related fun, and I am so used to riding with it now I think I would miss it.
On top of the fact all my other posts are a different size so I would need to buy a new post and clamp lol… which I would rather avoid as I’ve spent to much on this trip already.
I wasn’t actually trolling. The OP read like you had used it a few times (hence knowing that it was functionally fine), noticed the damage coming through then stopped working. If all that happened in one hit then its quite an issue!
So how often should they be ‘serviced’, do they just last until they definitely need it, or is there value in preventative maintenance like taking it apart and filling with grease/oil like a fork lowers service?
First time mine failed (all the air got out;-) i sent it straight to Fishers, whist CRC organsised the warranty repair registration. I had it back in about 4 days!
(since then it’s just failed again in exactly the same way so CRC are sending me a completely new replacement, so lets hope this one manages a bit more than 2 months between failures!)
Good that the warranty is being honoured and all that, but with all these failures reported, anyone questioning whether the product might actually be, well, a bit rubbish?
I have a suspicion that the quality and tollerance control in the manufacturing process is a bit pony. It seems some peoples items just work and keep working, whereas mine for example has failed twice with exactly the same fault! I think the basic design is ok, but when they have gone to volume manufacture (in Taiwan) some corners have been cut ot get costs down……….
The product isn’t rubbish, it does what it is supposed to do, and it does if very well. It’s a shame the quality isn’t up to scratch… At least they seem to accept this and have a good set up to deal with it.
Came back yesterday completely rebuilt with new stanchion apparently, not picked it up yet though.
The shop said it came with an essay of what has been done, then a lecture in servicing it more often, despite it being only 6 months old and the manual not stating anything about service intervals.
There was a fault internally do Everything has been done under warranty.
Anyone want a 6 month old, newly serviced reverb with many parts replaced? Will put it in the classifieds shortly.
Posted 11 years ago
Viewing 29 posts - 1 through 29 (of 29 total)
The topic ‘Reverb Failure… Guesses at what the outcome will be?’ is closed to new replies.
