Viewing 7 posts - 1 through 7 (of 7 total)
  • Reverb conection to Shimano lever – bracket ?
  • Trimix
    I know you can mount your Reverb lever to your SRAM brake levers.
    But is there a way you can do that with Shimano Levers ?
    I seem to recall a company made such adaptors, but cant find it by goggling 🙁
    benpinnick
    Doubt it – the reverb clamp is built in so you cant take it off and replace it with another part and theres no way to seperate the levers from their clamp.
    Trimix
    Perhaps it was a dream then ?
    markmck
    If you swap the Reverb lever to one of these I think you can then mount it to a Shimano lever with one of these. I like the idea but it’s a bit pricey.
    otsdr
    I’ve “locked” myself out of that option when I bought the rightside-only version of the Mismatch. Not sure if it’s a bad thing, though.
    Trimix
    @ markmck – that’s the answer. Just need to find out what spec my Shimano brakes are.
The topic ‘Reverb conection to Shimano lever – bracket ?’ is closed to new replies.
