Viewing 3 posts - 1 through 3 (of 3 total)
  • Reverb bleed woes
  • chvck
    I have a bit of a problem reverb that I’ve just done a full rebuild of, which involved (for various reasons) removing the hose from the seatpost. The lever is a RH one mounted on the left so I have to flip it over to bleed it. When bled it all seems to work fine but when I flip the lever back over it immediately stops working. Does this sound like a sealing issue in the lever?
    richmtb
    Reverb hoses are pretty intolerant of the barb’s not being 100% perfectly fitted.
    I just rebuilt my seatpost and it started to slow down almost straight away.
    So I made sure I properly tightened both barb’s (I used a vice and the yellow blocks you get with Shimano brake to get a really solid grip on the hose)
    I bled it again and it was spot on.
    chvck
    Interesting, thanks. I’ll give that a go.
The topic ‘Reverb bleed woes’ is closed to new replies.
