Are you sure it needed a bleed? I was thinking that and about to do it when the seat was not popping back up very well, and someone said just check the air pressure. Sure enough it was way down. Pump it back up to the exact pressure with a shock pump, all good as new. Several people I know found exactly the same.
Make sure the seat is all the way up, and pump to bang on 250psi.
You’ll note their instructions give dire warnings not to touch the air. Ignore that. No one knows why they’ve said that other than to cover themselves. Just don’t pump it over 250 and it should be fine.
