I have a brand new reverb which I have shortened the hose on and the bleed the system. However despite bleeding as instructions 4 times I don’t think it is working properly.
There is no obvious difference between the fast and slow settings. Both are slow compared to the ks lev I have on another bike. Additionally I need to push the button in a long way and have to maintain quite a lot of pressure. The pressure is set to 250 psi.
Any ideas other than keep bleeding until it works? When I create a vacuum at the actuator end, pulling up on the syringe, this causes the button to pull in. Does this mean there is still air in the system? If so how do I get it out?
