I worked it out with an online geo calculator with a 559mm axle to crown height (545, plus the stack height of nukeproofs external headset) and it came in at about 65.5
Which was a bit slacker than the official stats….
So the bike should still be plenty slack enough with a 150mm fork
Just checked – 150mm Revs have an a2c of 520mm, 535 with external bottom cup, 25mm shorter than above, which would put it roughly around 66.5 degrees, which makes my phone measure of “66-67” pretty good!
That means Lyriks at 160mm (545mm a2c) with internal cup would run about 66 as designed.
What headset are folk with 160mm fork running?
does anyone know the Torx head sizes that Nukeproof
Shock on mine is hex, pivots are torx.
Upper shock mount – 5mm hex
Lower shock mount – 6mm hex
Main pivots – T30
Chainstay pivots – T20
Hopefully it’ll stop pissing down soon and I can go and ride it rather than measure it!
