This is hopefully not your issue but it’s something I had happen to my Revs and the end result was reduced travel
The smallest seal on the damper shaft failed (it had a nick in it) and this allowed the damping fluid to slowly run through into the lower leg. The lockout will stop working before you get a reduction in travel. I had the fork warrantied by fisher (as the lockout stopped working and it was topping out badly) but they missed the problem and simply topped up the damper. Over the next few weeks to original symptoms returned and as the oil level in the lower leg had built up enough I started to see the reduction in travel.
It’s easy to check for, 1. is the lockout still working? 2, if the lockout has stopped working undo the bolt on the bottom of the lower leg to see how much oil drains out. Should be no more than an eggcup full, any more and you have problems. Also you can take thet top cap off the damper side, and check the oil lever, it should be 82-87mm below the top.
Good luck with it…
Can you get full travel with no air pressure in the fork?
