as the title says - have some 08 100 - 130mm Rev's they have stuck on about 117mm and will go no longer i want the full 130mm back (sure i've read about this before on here, but searched the forum - must have been on the old site?)
Bike Forum
Rev U-Turn's not extending to full travel
Posted 3 years ago #
Assuming they are similar to the pikes I have they are very easy to strip and sort.
Schematics on the rockshox site IIRC
Posted 3 years ago # -
if they are air forks:
completely empty both air chambers
pump the positive up to 100psi and check the negative again
Repeat above steps until neg shows absolutely nothing
Then pump up pos to desired pressure and match the negative chamber to thisPosted 3 years ago # -
assume they are air uturns as the range is stated at 100-130mm.
as above. this happens if the -ve air chamber has more pressure than the +ve.Posted 3 years ago # -
Just empty the neg chamber and your travel will magically reappear.
Then set the pos to your preferred pressure and then put about the same in the neg, sorted.
Topic Closed
