Have had a restricted 398cc single supermotard bike for a while now.
Just the quickness in which I have to go through up the gears 5spd is unreal. Obviously it's no hayabusa so stupid speed wouldn't be achievable in the 1st few gears.
Just would like to know from biker's on here, their own experience/views on what the difference(s) I will feel in ponies once the restrictor has been taken off which is up in early August this year.
I have managed to get 80mph out of the 33bhp 398cc single engine once but that it screams too much to do that all the time so 60mph is the sensible limit for this at present.
I'm pretty sure I have a 15t ring up front and a 41t ring rear and that it is standard ring ratios to have iirc.
I get the gist that the restrictor wherever it is fitted will be limiting the amount of fuel intake through the carb and out the other end thus limiting the speed. BUT in terms of what, acceleration? and to what percentsage would it knock off top speed I wonder?
Also I think I can recall that it can wear out the engine if ridden over the limits of the restrictor – to what extent is this true?
Also what sort of mileage would a supermotard engine achieve before needing a rebuild, I'm sure I've seen cases of 20,000miles before anything needs redoing which seems not much.
Also when the restrictor comes off, a new full system exhaust will be fitted to define noise 😆 and to aid in weight saving, looks and I guess a bit of powergain as I will get it rejetted at the point of fitting.
Not sure how many motorbikers are on this forum but seing as it's a two wheeled forum, I'm hoping a fair few.
thankyou for any advice.
