Weather has been so awful of late I decided to buy a Turbo Trainer and got a Tacx Satori with the magnetic resistance.
Using a road bike on it, at low rpm there’s a quiet hum which not unexpectedly rises in volume the faster I go. No problwm with that, however the thing that is annoying me is that as I buid up speed, a second rumbling vibration starts to build, but disappears again at higher rpm. At its peak it is really loud and very annoying. It’s not related to resistance level (ie if I stay in one gear, it kicks in and disappears across the same cadence range regardless of resistance setting. Ok, I can get up to a speed past the level that it happens at, but at some point in my workout I will hit a speed where it starts again and I’d like a better option than speeding up more or slowing down more!
It kicks in whether I am speeding up or slowing down. I’m not using a special trainer tyre, but a completely bald slick. I did notice when looking at it that there is slight buckle in my wheel, and possibly more significantly, the wheel is not perfectly circular – at one point the radius of the 700 wheel/tyre is about 2mm less than at most other points.
Everything is properly tightened up and there are no issues with play in the wheel bearings.
Anyone else experienced this and got pointers/suggestions to solve it?
1) will higher/lower tyre pressures help?
2) would more/less pressure on roller help?
3) would trainer specific tyre help?
4) would getting the wheel running more true help, or will I need to buy one of those special extra round wheels that the British track squad use?
Thanks for any tips/help!
