Can't seem to find a guide on the internet for this. Got a sticky piston which has crumbled a bit, so it seems like a good time to learn how to build a brake up as I currently don't really have a clue how hydraulic brakes work.
Is it simple as disconnect the hose/banjo thing, split the caliper, push/pull the old pistons out then push the new ones in with some red rubber grease (where do you buy this from?) then bleed? What about the seals, where do they go? Oh and is this kit all I need?
