One of my rear brake pipes started leaking – tried tightening the bolt and it totally sheared (looking at the routing, it was rubbing on the handbrake cable, so had presumably fatigued due to flex). It’s a short copper pipe with both ends mounted on the end of the suspension arm – the broken end going into the caliper, the other end attached to a flexible hose.
Car’s undriveable due to lack of brakes, so seems a lot easier to do the job myself, and hardly rocket science – just need to bolt on a new pipe, and do a fairly simple bleed job. The question is, where do I source a pipe from? Don’t really want to get into bending pipes and forming ends myself, would rather have something which just plugs in. Will a main dealer be able to supply such a thing ready to fit, or what do you reckon on my chances of the local independent specialist (more convenient to get to – he’s also who I trusat with work rather than the main dealer) selling me a pipe rather than doing the work himself? Alternatively, if I take the old one in, will a parts shop be able to make me one up?
I know I can find all this out phoning around tomorrow, just looking to short circuit that a bit and have a better idea of options, given it’s going to be a hassle anyway dropping off and picking up kids from nursery given I normally drop off in the car in the morning and mrs aracer picks up in the evening – no permutation of cycling to work really helps much with that.
