Viewing 6 posts - 1 through 6 (of 6 total)
  • Replacement Springs For Shimano Rear Derailleur?
  • druff
    My rear derailleur (Shimano XT) failed during last weekend’s ride and so I took it apart in order to investigate and give it a good clean. (For anyone interested, the Park Tools guide found here was really useful).
    I’ve discovered that there is little or no tension in the cage spring for the first 3 or 4 cms of travel when rotating the cage. Comparing this to a similar derailleur on another bike and the difference is significant. The derailleur in question is about 7 years old and has seen a good number of miles and associated abuse, but has been well looked after and as a consequence is otherwise serviceable, I’m hoping therefore to avoid spending the £50 on a replacement.
    I’ve searched a little online for replacement springs for the derailleur, but can’t find any on offer. Anyone know if replacement parts can be bought, and if so where from?
    Mister-P
    I have had to guess at the model number from your description but I think this diagram should show your mech –
    exploded view
    Do you mean the spring labelled as part number 8?
    druff
    Mister P, yep, part number 8 on that diagram.
    Mister-P
    Madison are expecting a couple of those into stock around 14/9/11 and they have an SRP of £1.49
    Part number is 5UF 1410 if you want your local bike shop to order you one
    druff
    Thanks for a really helpful response, Mister P. That’s above and beyond what I expected.
    Off to speak to the people at my LBS now!
    cynic-al
    You might get one from a borked mech from your LBS.
    I’d be surprised if a 7 year old mech had much life left in it though.
    Have you compared a new and old spring to check it is the spring and not some other factor?
The topic ‘Replacement Springs For Shimano Rear Derailleur?’ is closed to new replies.
