The E1700’s use the 28 hole E 512 rim, Madison code RE51228BK650. They’re standard eyeletted rims so don’t need special nipples or washers,
The old XM 1501’s (2-piece hubs) use XM 401 rims but if you fancy going wider the new XM 421 rims are available and are only 0.5 mm deeper so you should be able to use the same spokes. They use the PHR system and come with the nipple and washers included.
The both the E1700’s and the XM 1501’s use comp spokes.
Most of the 27.5″ straight pull alloy wheelsets use 284mm straight pull spokes front and rear Most Madison dealers will have DT Tech book that details all the spoke lengths for the current wheels.
Or,.. you could contact the U.K service, centre, TFtuned who’ll be able to get the proper logo’ed up replacement rims and all the correct bits and rebuild them for you.
Hope that helps.
