Last week I noticed oil leaking through the rebound adjuster on my favourite forks, 2008 180mm Domains. A quick bit of Googleage revealed that the rebound assembly was bished and needed replacing. After coughing up £55 those nice people at TFTuned sent me a replacement rebound assembly which if fitted this evening.
Gosh Rockshox forks are easy to work on.
However the fork is working smoothly but rebound is now super fast. Even with maximum damping on it’s just about at the speed it used to be with the old damper, when I would run it with damping about the middle of the range.
What is going on? Did I do something wrong? I reused the oil as it was less than a month old so that is not to blame and I used Rockshox recommended 200ml of 5 wt oil.
