A picture would really help, but essentially what I have is a tiered garden of which the bottom 2 tiers are supported by various sections of brick and block work.
I would like to make some drastic changes but I believe a large part of the tier work is for structural support in holding back the groundwork behind it, so in order to make a better use of the space im planning on removing a few courses here, relaying a few steps there, and eventualy covering the brickwork in white render and possibly decking boards in order to create a couple of brighter and more useful seating areas.
With regards to the render – im gussing you cant just go slapping it on neat over exposed brickwork, especially when the brickwork is essentially holding back earth?
I’d imagine that water/damp from the earth would potentially cause those big stains on the render that you sometimes see?
As things stand the brickwork appears fairly clean as drainage seem quite good.
I’ve had a nightmare tracking down local firms willing to even respond let alone quoting for groundworks such as this, hence why im thinking about a DIY approach.
It would make a massive improvment to a generally useless area right behind the house.
