Viewing 4 posts - 1 through 4 (of 4 total)
  • removing travel spacers
  • davewilson634
    Hi all currently waiting for my forks to arrive they are currently set @100mm Reba’s I want to remove travel spacer .can anyone advise me best way of doing this (first time) …..can I save oil or do I have to replace as they have just been serviced could do without new oil…thanks
    davewilson634
    Bump
    honourablegeorge
    I used this guide. REad it through so it makes sense, and then go for it. It’s a simple operation.
    If you keep the lowers sideways and you’re careful, you can do it without losing the oil – that said, it’s worth drainign the oil and putting in fresh as it’s not uncommon for new forks to come without much oil in them
    http://www.bikeradar.com/gear/article/workshop-how-to-adjust-travel-on-a-rockshox-trail-fork–26840/
    chief9000
    Hi,
    Are you sure that you can change the travel on these forks? I know you could do so by removing a spacer on previous models, but i think you need a “kit” to do it on more recent models. Which year and model you have?
The topic ‘removing travel spacers’ is closed to new replies.
