The guy I purchased the van off from Germany decided to have the bottom half of the van painted black,the reason he did this was because in the winter it snowed a lot and the bottom half got dirty very quickly !
It’s beyond me why he did this, there isn’t any rust to hide or filler etc but there’s no accounting for taste.
Underneath the black paint that has been applied is the original paint,it’s been sprayed on and very neatly,the paint can be picked off from the odd flaky bit and reveals the original paint work.
I’d love it to be all yellow again instead of a stealth bumble bee !
Any ideas how I can remove paint without damaging the original paintwork or should I leave well alone?
Many thanks
Ps if you’ve seen this on another forum then lucky you…
pps picture was from last year awful stars are long gone !
If the paint is shiny where it has flaked off this means it wasn’t rubbed down prior to painting.
A good blast with a steam cleaner will get the paint off in this case. If it wasn’t rubbed down I would have expected most of it to have fallen off by now.
So assuming it was rubbed down and painted with an aerosol you may be able to wash it off with thinners. This will leave you with a yellow van with the bottom half rubbed down. This could buff up with an electric mop provided they used fine wet and dry to prep with and didn’t rub through on any of the edges.
All of this is highly unlikely.
Leave it as it is and have a lie in instead tomorrow.
Take it a paint shop, you need to sort out what sort of paint it is.
If its a stone chip, then flat it back and paint over it.
If its celluose you might be able to shift it with celly thinners.
If you have got the time then it might flat off and if the yellow is thick enough it might polish up.
Bottom line, be prepared for a bottom half respay. anything less is a bonus. If you are going to pay someone to do the labour/sanding then don’t go straight for paint, it will be cheaper in the long run.
A big powerful one at the garage.
Looking at the masking line there’s no flaking there which leads me to believe it’s had a certain amount of prepping. You won’t get all the black off.
i like it like that. Painting the steel rims a colour and leaving the hub caps black would look cool i recon. You’d get a sliver of colour around the tyres. Seriously i’d probably go for something like neon pink (maybe)or neon orange and spray the vw badge at the front the same.But thats my taste.
polished and laquered steel ( if it can be done),or gold ( hammerite maybe around the edge??) or silver painted rims, both with the black hub caps would equally look good i recon.
Rub it down with 500 grade paper, till the yellow starts to show, then 800 paper, then 1000. Then into the yellow with 1200. Then T-Cut & several arm transplants later your done. 🙂
Even if you’re lucky enough to get it off, and you won’t be, what guarantee that the paint’s in good shape underneath? Could be old damage hidden. I think it looks good as is but if you do decide to get into removing it, make sure you’ve budgeted for a respray too as it’s all or nothing.
Posted 10 years ago
Viewing 27 posts - 1 through 27 (of 27 total)
The topic ‘Removing spray paint from the original paintwork… car related’ is closed to new replies.
