Peaty allegedly uses Matrix pads, which have no friction co efficient, so he could use 2 bolts without any dramas. My old Hopes , used to have a splined spider centre and 3 bolts holding the disc to the spider. This was their Mk1 version of the hydraulic disc systems, then they went to 5 bolts. I managed to pull the bolts out the disc and had to re engineer with longer bolts and nylocs on the back, even though Hope said I cant have done it and then they made a 5 bolted version. They are obviously never wrong 🙄
I bought some Ti bolts for a lightweight build and looked scared in fitting them, so refitted steel ones and use the Ti ones for bottle cage blanking bolts.
As for the probable Team Cannondale bike above, that lefty plastic cover on the leg is held on by 3 bolts and is a lump of plastic and for a team bike getting stone damage on the stantion is not an issue, just fit a new fork and taking it off will save more than the bolts on the disc.
The hubs could be redesigned in having a locating pin sticking out of 2 bolt holes and then fitting 4 bolts on Peatys bike, but as everyone says, the weight saving especially at the hub, is about the same as a bogey clearout before riding.
