I need to remove a pedestal sink and to be honest, I’m cacking it 🙂
I’ve been quoted £80 by a plumber. I’m not cacking it to the tune of £80 though.
Am I right in thinking that I need two cut off valves, turn the water off, run the taps dry, cut the pipes to the taps, remove the sink, take up the floorboard it’s standing on, cut the pipes again under the floorboard, fit the cut off valves, ensure they’re turned to off, remove/cut the waste pipe under the floorboards, put the floorboards back, turn the water back on, bin the sink and pedastal, all will (theoretically) be good?
Or even better, any plumbers in Stockport willing to do it for less between Friday morning and Sunday evening (Monday at a push)?
