Neal – Slight hijack – looking at using a clay bar on my t5 before giving it a wax ~ any recommendations please?
Also, after touching up stone chips, is wet and dry best to get an even surface? And can I use a buffing compound with my dremel mops to get a good result?
Thanks
Built Hamber Autoclay is good option, and its designed to use clean water as a lube so it’s not necessary to buy a second product.
Otherwise Meguiars do a full clay kit for about £25 that has everything you need.
I would use a good Tar and Glue remover first though personally, saves the clay bar a lot of work lower down the panels.
The finest grade wet and dry you can find, soaked for 30 mins in clean water, and used with a rubber sanding block would do the job! go easy though !
wouldn’t have a clue about using a Dremel. Sounds like a really bad idea though.
There are correct tools for the job, personally I would stick to using those.
Fast rotary machine with a G3 foam waffle pad and polishing compound.
