Okay, it has been nearly a fortnight since I banged my knee. The scabs have healed and the pain in the joint has subsided but it is still really swollen and the skin surface us very sensitive (hurts when clothes touch). It is still swollen enough to make it hard to bend my leg enough to pedal.
Technique so far has been gentle movement, 400mg Ibuprofen for breakfast, lunch and tea.
Any better suggestions for reducing the swelling before I go and see a proper Dr?
Umm. I did something similar almost a year ago. Although I’m guessing a little worse as I was on crutches and told to lie on my back for a week with my knee above my heart.
Rest, Ice, Compression and Elvation is pretty much your solution.
Is there a hematoma at the impact point? There is a real danger of these calcifying in the soft tissue of the legs.
If it has been 2 weeks and you are still in quite a bit of bother i’d go and see a doctor.
When i dislocated my knee the swelling took quite a while to go. Ice on it regularly really helped mine.
I got the gel ice bag things from boots and had one at home and one at work, i would ice my knee at tea breaks and lunch at work and in the morning and a couple of times in the evening at home.
swelling took a long time to go down and I still couldn’t bend my leg pain free after 3 months.
ended up with an MRI (clearish) and a course of physio for a dodgy tendon in the back of my knee – I’d torn it and when it had healed there was a little lump on the tendon that was irritating surround tissue as I moved my leg.
Physio basically rubbed the tendon until the lump went. This was quiet a painful experience.
Right leg looks fine I’d be more worried about how skinny the left one is.
Get to the GP, you need to be fit enough for your stage dive at you know what in a couple of weeks 😉
I didn’t say I didn’t like your legs, I said I wouldn’t like your legs if you were a girl. Which you’re not. So I was defending you, from a certain point of view.
I went to A and E with something similar (to diffcult to get to doctors appointment) in my elbow. Had nearly 3 weeks of antibiotics. Didn’t clear it went on rugby tour and I assume because the blood was pumping round hard for the 2 games it spread the infection. My left knee and all below became inflamed and my kneck was agony I ended up calling an ambulance after a few days at home. Spent 8 days in the hospital the doctors decided I had some sort of Arthritis spent 2 weeks at home unable to get off sofa. Found out I had an infection in spine (MRI scan) when it got there or how it got there is anyones guess, certainly doctors couldn’t think of no reason for it to get there. Ended up another 5 weeks in hospital and been on crutches for 4 months (septic arthritis in right knee). hoping to get back cycling soon. Although walking without crutches appears (judging by the pain to be creating more damage) So have bought walking poles to get me in the pubs once I get to one.
I think you need to check for an infection “the skin surface is very sensitive (hurts when clothes touch)” sounds suspciously like an infection although it also matches Gout?
Cougar – since the operation….actually, I just didn’t read your post properly. Of yource you can have one of my bikes when I die. Amputation is but a flesh wound so I will be adapting my bike to work for just one leg.
PS Diclofenic (spelling may be iffy) is the prescription anti inflamatory although I use Arthretic 75 which has another ingrediant as well. Alowes me to spend an hour on the exercise bike everyday although my knee is bit swollen afterwards. Mind walking/standing for short periods has the same effect.
Looks like bursitis to me. I also had it after a crash on my bike. It took 6 weeks of continual draining and an operation to get the congealed stuff out before I was able to walk properly again.
Re arnica, TSY, Cougar, you are both correct, Arnica itself may be useful, it’s unproven though, but it’s often prepared as a homeopathic treatment, rendering it definitely useless…
Secondly, cougar are you being ironic/sarcastic as the evidence for arnica is about as strong as that for acupuncture and I said pretty much what you did above and you tore a strip off me.
I can get hold of dozens of plastic knives from the work canteen. I can be round this evening to perform the amputation. Please CLEARLY mark the one to be cut off – that was such an embarrassing mistake to make last time.
When it’s done, I suggest hanging it up in the garden for the Blue Tits to peck at
Has your GP organised for an x-ray/MRI at any stage??
The stuff coming out of there looks remarkably blood stained; you don’t tend to get blood in joint spaces without fractures or damage to the big ligaments holding it all together (in this case I’d worry about your cruciates)….
Just a thought, with all the usual about not knowing how you did it, or having seen/examined it, or had a good look at the stuff coming out of it….
This got bigger and blacker and starting from just below my groin and over the next couple of day moving down my leg giving me swollew and bruised looking ankles.
Injury was cause by the chain coming off the bike followed rapidly by me coming off the bike and using my knee to stop my entire body. Must have been reasonably hard as the people watching all went quiet until I moved rather than the normal laughter.
No real pain in the joint, just tightness from the swelling which is much relieved today. The skin is very sensitive though, short rubbing against it actually hurt.
