Spank lounge bars and stem
Wear and tear around the grip area, will cover up. A few scratches, etc on the bars. but overall not bad.
£28 posted
Oakley eyepatch sunglasses
£43 POSTED
Hardly been worn. Arms are tight and like new. Lenses have a few marks, no major scratches just very small marks around the lenses. Oakleys have stop making this model. IMO the best looking model but i dont think they suit me.
Spank subrosa rims on hope pro2 hubs
£190 posted
QR rear and 20mm front, in good condition, hardly any marks, not been used that much. Cassette is a bit dodge on the small ring but will chuck it in. Tires are not included.
think i have the 135mm QR for the rear if needed
thomson seatpost. 30mm by 410mm
£35 POSTED
came off my cove stiffee. a few marks around half way up that i have tried to capture with the camera. There is a few marks around the same area but the rest of the seatpost is pretty much unmarked. The marks will be hidden unless you have your seatpost super high.
Bataleon Snowboard NEW tee LARGE
£20 posted
Bought for 33EUROS FROM AUSTRIA/BLUE TOMATO. Didn't return it in time. Nice fit, im just fat.
Shot at 2012-02-06
GUSSET slim JIMS
Used condition £11 posted.
FOX TALAS 36
They need a service. When ridden hard ( and i mean hard) they leak slightly from the seals. They dont leak a lot but still leak. Also the lock settings don't really work so well anymore. I have always just left them on the 160 setting. They have served me well. Could do with TLC or if not then just fired onto a bike and off you go they still do their job.
Used conditon with signs of wear and tear. Little wear on stantions also. I will supply with a 20mm axel that come with its own special tightening tool as the allen key hole is rounded off so i had to fashion my owm contraption. Good forks for someone thatdoesnt want to spend £700 NEW. steerer 225
£105 posted
Crank brothers cobolt 31.6 by 400mm
bit of wear around the base. No scratches as such just wear from use/moving up and down. Still in really good condition.
£23 posted
Lizard skin peaty grips
£5 posted
Used, few scrapes on the rings and wear on one side of the rubber.
Older style xt front mech
used condition
£7 posted
husselfelt stem and bars oversised 50mm rise. used. one obvious scrape, otherwise a few minor marks
£26 posted
