I posted about this on my nearly new 335 solo airs. Well it sounds like the same thing. Some one said it was par for the course but I was unsure so phoned TF tuned.
They said you're feeling the play in the floating piston needed in a solo air fork. This equalises the pressure, at the end of the stroke, between the positive and negative air chambers. I've carried on riding with no problems. However they said if was more than a few mm or the fork was loosing air it was a spring breaking up that would wreck the fork. They were certainly confident that what I descibed was in the air spring not the damping side
If it is the floating piston then its weird that you have never noticed before.
I hope this helps
