Viewing 14 posts - 1 through 14 (of 14 total)
  • Recommend me an insect repellent
  • CaptJon
    I’m off to Finland in a few weeks, and going to need some decent stuff.
    Nobeerinthefridge
    Smidge
    joshvegas
    Smidge^
    CaptJon
    That was quick. Cheers.
    honeybadgerx
    More smidge. Though only ever used it for midges and ticks, though think the blurb says it works on mozzies as well.
    scotroutes
    Has anyone suggested Smidge yet?
    Kryton57
    Boots Repel Tropical strength. The gel seems better than the sprawl but both available in a “compact” delivery system.
    rene59
    Smidge
    stayhigh
    Last week in Greece I forgot to take Smidgen so ended up using THIS which worked quite well.
    I still got bitten a few times but my o/h who wasn’t using anything got eaten alive.
    globalti
    Anything with DEET will work fine. It just depends on whether you like the delivery system – lotion, gel, roll-on, spray, whatever.
    DEET is readily absorbed and comes out in your urine for 48 hours after application so if you don’t like that idea, try the good old Avon Skin-so-Soft Woodland Fern oil-based perfume spray. I believe this works by masking your exhaled CO2 and body odour. Avon want to drop it but can’t because it sells so well.
    scottalej
    Mosi-guard Natural
    prezet
    This should do the job …
    nickc
    Always used Jungle, it’s DEET, it works, it’s cheap and widely available.
    dashed
    I thought the active ingredient in Avon SSS had been dropped a few years ago and it no longer works on mozzies.
    Another vote for smidge.
The topic ‘Recommend me an insect repellent’ is closed to new replies.
