The quality of these things is amazing for the price.
+1
Haven’t had one, and havent’ seen one till you posted that link. But go to the swan bearing catalogue and you would struggle to get the two bearings for that price, let alone the cups!
I’ve had the same headset for about 8years, was an OE internal fit FSA ??? something or other I got on a giant AC in about 2003, its hard about the hardest life of any headset ever, but I finally had to retire it last month after I changed to a frame that needed an external headset. Its still smooth as it was when new and has required precisely ZERO maintenance!
The thing on this new frame is WTB OE fit thing and has loose ball bearings which I’ve ignored and have eaten their own bearing races, my bad, but still, show’s the difference quite clearly I think!
So I’m also on the hunt for a new one, but it will be at the cheaper end of the scale, external, 1.1/8″ and sealed angular contact bearings or nothing.
Loose balls are for road & track bikes*
*on any wooden track, AFAIK all forms of grease are banned. Hubs, headsets, chains and BB’s are all run dry aside a few drops per ride of machine oil (as this can be cleaned off the track). And if you have a good one, the smooth’ness and friction is crazy awesome
