Hi,
Got the singlespeed bug, now looking for frame for ss bike.
Currently, I have ben riding cube ltd frame (2006), simply not changing gears 🙂 I want to keep this bike as geared.
This one has appx 70 deg ht, 72 st, longish htt of 590-600mm and quite low bb. This is in size 18″, which is ok for fast xc but to much for ‘every day’ fun.
So, I’m looking for something shorter and more relaxed in terms of HT, ST of 72-73 is fine. My other bike is spicy in S, which fits great (I’m 5’8″).
I like the idea of light fast xc/trail frame , something like c456 or even ibis tranny (too much money). But I’ve missed cheap c456. Second hand is also ok, and will probably the route to take. Frame should cope with small drops (1-2 feet max) and take appx 120 fork (do not want to go higher than 140). Guess that rulles out whippet.
What is the difference (in ss context) if using 6lbs steel frame or 3lbs carbon one, if all builds are the same? I know that it rides differently (steel vs c), but other than tht its mostly weight, right?
Not too fussy about the weight though, my cube weights 13kg and its a speed machine compared to spicy with dh tires 🙂 I use for most of riding now.
I assume its better tovuse horiz. dropouts and chain thugs insted of faffing with ebb or tensioner?
Thx for your help,
Igor
