Best advice is to have a High one for shocks and a low one for forks, better accuracy (same assumptions about the loss not coming from the fork/shock)
Yeap – fork is fine. It’s the smaller air can and fiddlier access of the shock that’s the issue.
It’s probably not letting out air from the shock, all pumps do this it’s the pump itself.
it’s not actually dumping air from the shock, it’s just the air escaping from the shock pump hose (the schraeder valve on the shock only ‘opens’ when the pressure on the outside- ie the pump exceeds the pressure on the inside – the shock)
That’s what I initially thought / hoped, but I’m not convinced after several sessions trying to set shock pressure, and getting different results each time depending how long it took to remove the pump from the shock valve. The pump itself is over 10 years old so I don’t mind relegating it to backup duties.
Has to be said, that DT Swiss looks like it has the same body as the pump I already have (and Bike Hut, Fox, RockShox, Airwave…) 😉 BUT that connector looks interesting.
After a bit of searching, this looks like an interesting alternative to try as well: http://www.wiggle.co.uk/topeak-pressure-rite-connector/
Does anyone have any experience of one?
The only thing you might consider is maybe a Lezyne shop, or an Airace Digital (Sold under many guises) pump, as both of these have much more precision to the display, allowing you to really fine tune the pressure.
Thanks – I’ll have a look-see.
After looking at the cheaper option above…!
