I went for an Intense Tracer 275, you can run it 140 or 160 at the rear, the head angle is slack, but not Enduro weapon slack like a Capra or a Nomad (but slightly slacker than a Bronson). Works well everywhere.
The only slight annoyance, it was sold as being “two bikes in one” with the adjustable rear travel which I suppose it is – well two bikes that weigh the same, the problem with that is that whilst you only have to undo a bolt and move the rear shock mount to change the travel, you can’t keep the same shock tune – I don’t pretend to know how or why, but the sag % changes as does the rebound speed, it sort of works it goes from a 160mm gravity bike running 30% sag to a 140 trail bike with 25% – rebound gets quicker at the same time so it makes it more sprightly, but it’s not exactly where I’d want it.
TBH I leave it in 160mm most of the time, it barely bobs at all climbing (Float X CTD) and doesn’t make it feel too lumpen on the flat stuff.
