• This topic has 44 replies, 39 voices, and was last updated 9 years ago by sync.
Viewing 40 posts - 1 through 40 (of 45 total)
  • Recommend me a multi tool with chain tool !
  • paulmgreen
    This evenings ride cut short by a snapped chain…… Not had this before ! End result a 4 mile walk to civilisation !
    Funnily enough just a couple of days ago I was watching a video about what to carry on a mountain bike for emergencies….. One of which was a multi tool with chain tool for exactly the occasion I had tonight…..
    So gentlemen….. Recommendations !?
    curiousyellow
    Crank Brothers for me. I have had to use it for trail side chain repairs a few times. Can’t fault it.
    Simon
    Topeak Hexus
    andeh
    Have had a Topeak Hexus for years, it’s been great.
    edhornby
    Get a separate chain tool, park do a small one that is good quality
    breadcrumb
    Another vote for Topeak Hexus, great tool.
    Rscott
    topeak alien2
    carlos
    Crank Bros 19. Poss only thing they make that lasts and works and it should.
    rideforrestride
    Another vote for Crank Bros 19
    Chris
    CaptainFlashheart
    Hexus. It’s teh shizznizz. Or something. Seriously good, really.
    colournoise
    Chain tool on my Topeak Alien 2 is awesome (assume the Hexus has the same one?).
    Northwind
    Hexus, the official tool of STW. Really that good.
    CaptainFlashheart
    Pretty sure that there are a few other contenders! 😉
    butcher
    Topeak something or other here. Bought it 10 years ago. Still works great. Which is good enough for me.
    andyv
    Hexus
    geoffj
    Hexus is hard to beat, but birzman do one which is supposed to be good.
    Jamie
    bigblackshed
    Topeak Hexus.
    I’ve got three. One in the hydration pack, one each in two saddle packs. I’m OCD with tools, kit and spares when out on the bike. I don’t double up, just CBA swapping kit between bikes. Never let me down yet.
    edlong
    This. I find a chain tool much easier to use when it doesn’t have a multitool hanging off it.
    RobHilton
    And for balance…
    Not this. The chain tool on the Hexus is much better than many separates
    jsync
    topeak rocket ratchet (not the lite one)
    look no further
    carlos
    And for balance…
    As is the CB19 IMO
    grtdkad
    Topeak Alien II in my kit.
    njee20
    +204 for Hexus.
    walla24
    park rescue tool…new version has some awesome shiz
    MikeWW
    These Lezyne are brilliant
    shedfull
    +2 for Hexus as I bought another for the road bike. I’ve used the chain tool and it works better than my mini Park chain breaker – more leverage. If only I hadn’t lost one of the 6mm hex adapters.
    chiefgrooveguru
    Chain tool on my ancient Topeak Alien is excellent.
    nikk
    FIFY
    BTW, Finishline Chain Pup FTW.
    FOG
    Another vote for Lezyne ,fixed a chain quickly in driving rain at the top end of Nidderdale when the alternative was a long walk.Doesn’t weigh much or take up much room either.
    I was disappointed in the tiny Park chain tool which broke the tip the second time I used it.
    Jamie
    Has the OP bought a Hexus yet?
    steve_b77
    Crank bros 19, still going strong after 5 years and the chain tool is teh awsum
    Ecky-Thump
    The superstar £18 one is actually really nice. The chain tool is better than my separate toolkit one.
    Superstar multitool here
    rhbrhb
    Topeak Mini 18 done the job on mine and strangers chains on a few occasions over 8 yrs.
    bob_summers
    Lezyne one snaps when you need it to do exactly the opposite. Will be replacing with a different one.what does the hive mind recommend?
    crispycross
    Crank Bros. The Hexus is let down by a couple of things. It has loose bits for 8mm hex and T25, so they’ll get lost the first time you use them in long grass, plus you need to prise a bit off the side to use as a lever on the chain tool. On the CB, you need a bit more oomph to use the chain breaker, but it does work well and there are no small loose parts.
    johnny
    I wouldn’t recommend the Crank Bros one- it has a little knuckle on the chaintool that is there to stop you pushing the pin in the chain too far out. Unfortunately this means you can’t always push the chain far out enough to split the chain without bending the outer link, which then compromises the integrity of the chain after repair.
    (As i found out at Gorrick on Sunday…)
    However, i’ve had mine for years, and the design may have changed/or i might have just worn the pin on the tool down too far…? Id rather have one without this restriction, especially for use on SS chains too…
    curiousyellow
    I used my CB tool to link my SS chain and to bodge a pin back in when I figured out I’d shortened it too far. Wasn’t too much hassle, but I was doing it in a garage and not trailside in a race. That’s what the KMC quick links are for!
    paulmgreen
    We’ll…. Thanks for all the input fellas……. I opted for the Hexus ……… In a way I hope not to have to report back on its effectiveness…… Fingers crossed. 🙂
The topic ‘Recommend me a multi tool with chain tool !’ is closed to new replies.
