As wasnotwas said – they are called desiccant dehumidifiers. They have the added benefit of warming the room too.
We have one of these (came recommended from someone on here I think) to keep moisture under control – great for drying clothes too. It has been very good since we got it and on the lowest setting it is very quite – enough to be able to sleep in the same room with unless you need absolute silence. I can sleep with ours on but it annoys my wife so we just switch it off overnight.
I think you’ll be struggling with that bit – they mostly have compressors in them so will make the same noise as a fridge.
No they don’t – desiccant ones are considerably quieter – the main noise comes from the fan. They work by absorbing the moisture into magic* crystals and then they are dried using a small heater/fan in order they can absorb more moisture.
*They are probably not magic.
