Middleburn with a dual atb spider?
Sugino do a nice compact if you’re after square taper called the Alpina.
If you want some dirt cheap cranks I’d recommend these – there are basically Sugino/Stronglight Impact crank with no name on them. For £20 you can’t really go wrong (and there’s a triple version too if you want).
Spa XD-2 cranks
If you want some retro shiney ones have a look at this US guy – he ships to UK
Velo-Orange
If you want 2-piece, it’ll be either SRAM Rival (or S350 or Truvativ Elita version), Shimano R600 or maybe a Campag one (mind, the new Campy cranks run their own proprietary chainring system with one bolt off centre just to annoy you).
And if you really want a low ratio compact, check out Stronglight Oxale 2 (also from Spa) – its a double CD 94bcd chainset running 29/44 as standard!
