• This topic has 40 replies, 20 voices, and was last updated 8 years ago by STATO.
Viewing 40 posts - 1 through 40 (of 41 total)
  • Recommend a Surly Cross Check that isnt a Surly Cross Check. STW challenge!
  • RustyNissanPrairie
    Here’s a challenge for STWers!
    Am looking for a replacement for my aged Kona Smoke 29er flat bar commuter. Bought years ago for not much but now mudguard less and running full cast off 9spd XT and a few King and Thomson bits.
    Is brilliant for taking the long route home and generally not being in much of a rush.
    I think the closest is a Surly Cross Check but I dont like the forks or the non sloping toptube.
    So, recommend a steel, 29er/700c flat barred, 61/62cm frame with rigid forks and either cant/v mounts or discs with a dropped toptube or that doesn’t look like a gate
    Over to you!
    ton
    singular swift.
    Bregante
    Kaffenback?
    Ah no xxl
    RustyNissanPrairie
    singular swift.
    Too small
    Kaffenback?
    Forgot to stipulate – not interested in PlanetX/On-One
    johnnystorm
    Genesis Vagabond?
    piemonster
    You thinking of the same price point?
    CaptainFlashheart
    Does it have to be steel?
    Saw one in the LBS the other day. Looked far better than it should have done!
    ton
    salsa vaya.
    salsa fargo.
    johnnystorm
    Just read the bit about flat bars…duh.
    piemonster
    I think that’s a sign of getting old, like leaving the milk in the microwave instead of the fridge.
    And smelling of cabbages.
    There the 3 main signs anyway.
    RustyNissanPrairie
    The Salsa’s are drop barred (and I already have a Norco Search gnarrmac).
    The tripster ace is getting there…..but needs to be steel and a F&F only.
    Its not easy is it!
    john_l
    Cotic Roadrat?
    MussEd
    CFH IN NON-SPECIALIZED RECOMMENDATION SHOCKER,
    CaptainFlashheart
    Tougher! Hmm.
    Have you considered a Specialized? 😉 (FWIW, my recommendations are many and varied…! Sometimes, they’re good, too! )
    cloudnine
    RustyNissanPrairie
    the RoadRat is exactly it !!!!!!!! Nailed it.
    Except its tiny and they dont do an XL!
    ton
    surly ogre 24” fitted with slicks.
    MussEd
    Mm, If only there were a LiKE button…
    piemonster
    You sure you don’t really want a Straggler!?
    RustyNissanPrairie
    I cant stand the look of the Surly Cross Check top tube – its even worse on the Straggler opposite sloping TT!!!
    cloudnine
    Go see shand
    thetallman
    Works for me.
    Can’t help you with “doesn’t look like a gate” though 😉
    RustyNissanPrairie
    this is going to sound daft – but I dont like the fussiness of the Ogre – too many braze ons as it tries to be all things to all men (and women possibly?) and I prefer one or the other brake wise – disc or canti but not both.
    piemonster
    All City Macho Man frameset
    RustyNissanPrairie
    drop bars and too small !
    STATO
    I’m sorry but do you actually have a clue what you want?
    You have a flat bar hybrid and want a cross check despite the fact the crosscheck has a horizontal top tube, short cyclocross forks and is designed for drop bars all of which you hate. You also don’t want other dropped barred bikes that have sloping top tubes. You don’t want a swift either because it’s too small, despite the fact an XL is bigger in every dimension than a crosscheck due to the fact it’s an MTB and designed for flat bars not drop bars and has a sloping top tube you want. 😀
    cannondaleking
    What STATO said!
    Go custom made dude save up hit the CC and get it made your way
    Retrodirect
    Soma Wolverine.
    Del
    the ogre is a monkey, without the piercings, isn’t it? or the other one? get that. 🙂
    cynic-al
    Why replace a Nike you really like?
    Never seen a custom high end hybrid. Hope I never do lollllololol
    itstig
    have you looked at the 650b straggler?
    trail_rat
    Al you need to speak to turbo ferret.m
    Sam
    XL Swift really too small? 640ETT. How tall are you?
    shermer75
    Surly Karate Monkey Ops (vertical dropout) in 22″ at Charlie the Bikemonger
    http://www.charliethebikemonger.com/surly-karate-monkey-ops-frameset-4811-p.asp?v=0&variantid=4820
    shermer75
    How tall are you, OP? A 61/2cm frame with a dropped top tube sounds pretty big….
    RustyNissanPrairie
    So this is what Im looking to replace;
    Its a 22″ frame C to T so is approx 56cm, my Norco Search is a 61cm frame.
    Sam
    Sam
    You eeally need to compare ett or reach, seat tube length doesn’t dictate overall fit.
    mrfrosty
    Jones plus 25″
The topic ‘Recommend a Surly Cross Check that isnt a Surly Cross Check. STW challenge!’ is closed to new replies.
