Viewing 23 posts - 1 through 23 (of 23 total)
  • Recomend me a spoke key.
  • TheSwede
    Mine is shite. One of these. Knackers nipples.
    Also what size is the 15 equivalent to or what is the most common size.
    Cheers.
    simondbarnes
    Red Spokey
    CaptainFlashheart
    Park or a Madison Spokey. Nothing else worth looking at.
    markenduro
    +1 for park
    PePPeR
    I'm a Spokey fan too, I can work with them quicker than anything else.
    http://www.cyclesportsuk.co.uk/product_info.php?products_id=1068
    singlespeedstu
    Park is the dogs doodars.
    fotorat
    i've got the triangle park one – doesn't slip but kills your fingers – no good for wheel building
    craig1975
    Spokey key here too
    TheSwede
    Cheers guys. Will give the red one a pop.
    Brother_Will
    Ive had one of these since i did my training, solid and dependable with a 4 sided grip
    Clicky
    Cant say ive ever been a fan of the spokey ones, or the park professional ones ive tried them both and have always gone back to the one in the link above.
    coatesy
    If you buy a Spokey,try and get the Pro version as it has a deeper jaw and is less likely to slip or damage nipples.
    woodsman
    So does, Topeak Alien soke key (wreck nipples) where can I can the pro spokey?
    trail_rat
    dt spokes – red spokey pro
    standard spokes – yellow spokey pro
    Munqe-chick
    red and yellow spokeys in the garage tool box, all-in-one BBB tool in the camelbak, similar to this but think my is ally not cromo
    http://www.ukbikesdepot.com/products.php?plid=m11b0s72p1334
    comfy enough to use to build a full wheel, and should fit any wheel in my riding group if needs be.
    uplink
    You can have a real fancy one with a red cross in it for £14
    http://www.chainreactioncycles.com/Models.aspx?ModelID=31322
    Or one with a hole in it for £5
    http://www.chainreactioncycles.com/Models.aspx?ModelID=19098
    I guess the cross was hand carved or something? 😉
    woodsman
    Cheers, but I want the red spokey pro – where from?
    ta
    montylikesbeer
    I have a Park, its very good
    woodsman
    One with a hole – cheers!
    Now where can I but DT spokes – can't find them on CRC?
    ta
    Stoner
    I have a sapim one. Not sure where you can get them from – i got mine from a sapim sponsored wheel building coach.
    cost a fair bit, but its solid metal, very comfortable to use and with a well formed key.
    BigJohn
    The one in the top pic makes a crap spokey but is good for removable tubeless valve cores.
    Sam
    Black Park Pro here. The four sided designs I find a bit of a pain as you have to slide them over the top of the nipple rather than from the side which takes more time.
    tangobravo
    Best spoke key i have ever tried after exploding a spokey:
    P&K Lie spoke key
    made in germany, so not cheap!
    thisisnotaspoon
    yellow spokey for just about everything
    red spokey for just about everything else
    swearing and molgrips for other sizes
The topic ‘Recomend me a spoke key.’ is closed to new replies.
