Viewing 13 posts - 1 through 13 (of 13 total)
  • Recipes – what to do with a leg of lamb
  • AndyPaice
    I have a leg of lamb and fancy a roast. Usually do garlic & rosemary, any suggestions for livening things up?
    Junkyard
    list it on classified you will get a response from someone 😆
    AndyPaice
    I’d have to chop it into little pieces and put up loads of threads though
    andym
    Mint sauce?
    AdamW
    In t’oven set at 120C for seven hours. With rosemary and garlic.
    Yum.
    Junkyard
    superb LOL
    IanMunro
    As little as possible ie. what you do at the moment. The meat should speak for itself imo.
    KingofBiscuits
    I remember watching some food porn programme on the bbc and thought this looked good:
    http://www.bbc.co.uk/food/recipes/database/honeyroastedspicyleg_86764.shtml
    Certainly different.
    D0NK
    That honey roast lamb looks good.
    I do a lamb leg curry occasionally, fry mustard seeds, cumins seeds, onions and peppers in seperate pan. Put some oil in a baking tin on a hob get it good and hot add all your spices/garlic and fry for a minute, then seal the lamb leg all over in it. Add 1lb or so of chopped tomatoes, lob in the contents of the other pan. (that’ll do if you want a fresh homemade type curry but for extra sauce I also add 2 tins of conc. pataks tikka masala) Cover and bung in oven at g.m.4 for 5hours+ turn meat every half hour (cook lower and for longer if you have time). Add loads of rough cut fresh coriander and a bit of double cream at the end, meat will fall off the bone, then you can shred it or roughly chop it up for serving. (with rice and naan of course)
    Spices
    1tsp ground cumin
    1/2tsp garam masala
    1/2tsp tumeric
    2tsp tandoori powder
    1/2-1tsp chilli (or fresh chopped)
    1tsp ground coriander
    1tsp paprika
    2-4 cloves garlic
    1tsp salt
    1/2tsp sugar
    1tsp ground black pepper
    (the cream smooths the taste, if you don’t fancy it you can add lime juice before it all goes in the oven for a slightly different taste)
    takisawa2
    Sew it back on.
    Spongebob
    IanMunro – Member
    I never had joint of meat talk to me, ever!
    KingofBiscuits
    You’re not on the right medication then Spongebob
    AndyPaice
    excellent 🙂 keep em coming
The topic ‘Recipes – what to do with a leg of lamb’ is closed to new replies.
